copy,move operation
ptc-697016
copy,move operation
Hi users-
I created an operation with many toolpaths.
I want to move some of the toolpaths to
another operation. I can copy them within an
existing op but I don't know how move them to a new one.
wf 2.0
Thanks Rob Jeanjaquet
Rob
Make sure your second operation is before the NC sequences you want to
switch.
pick the NC sequence from model tree and edit refrences and select the nerw operation when it prompts for operation, you can replace any other refrences also at this stage or use same refrences if you don't want.
Pushkar Khanna
Rob
switch.
From the model tree pick a NC sequence then RMB and pick edit definition.
Check the operation box and pick the second operation
Ed Webb
FPD Company
Design/Programmer
ejw@fpdinc.com
