Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I created an operation with many toolpaths. I want to move some of the toolpaths to another operation. I can copy them within an existing op but I don't know how move them to a new one. wf 2.0
Rob Make sure your second operation is before the NC sequences you want to switch. pick the NC sequence from model tree and edit refrences and select the nerw operation when it prompts for operation, you can replace any other refrences also at this stage or use same refrences if you don't want.
Make sure your second operation is before the NC sequences you want to switch. From the model tree pick a NC sequence then RMB and pick edit definition. Check the operation box and pick the second operation
Ed Webb FPD Company Design/Programmer ejw@fpdinc.com
