Is it possible to create acylindrical coordinate system in WF4? I only see how I can create a cartesean coordinate system using an OFFSET definedin cyclindrical terms(r, theata, z) but NOT how to create a cylindrical coordinate system.Searches of theHelp CD and these forumsdid not help. Inthe forums I found severalduplicates of this question (all being answered incorrectly with "set the offesttype box to cylindrical"), but no answers that actually produce a cylindrical coordinate system.
The reason Iwant a cylindrical coordinate system is that I have an analysis I am trying tocomplete withPro/Mechanica and in it, there isa radial load that I would like to apply. I am assuming that if I apply a load with itreferenced to a cylindrical coordinate system it will allow me to define an appropriate direction vector to produce the desired radial loading. I will also be posting this up the CAE forum...
thanks...
In Pro/E all coordinate systems are "universal". They can be used as cartesian, cylindrical or spherical as needed by what ever feature(s) reference them. Fo example, if you want to make a datum curve by equation you pick a csys and within the dialog box can toggle the csys type to what you want. Thus one csys can be used as multiple types at once if you want. I don't know how you specify the type in Mechanica.
In Reply to Paul Korenkiewicz:
thanks...
PTC quality philosophy: We've upped our quality standards. Up yours.
