new to ptc creo 2.0. How do i delete a circle/line or any item once it is sketched?
If you are in sketch, you are editing the definition. You cannot select the feature with a left mouse button?
Highlight; right click; delete. Or highlight and use the delete key.
You have to be in the sketch. You edit the sketch with Edit Definition (right click in the model tree)
I am not able to highlight it. In the sketch view, how do I get to Edit Definition. I have the student edition.
Thank you.
You are welcome.
