disabling and enabling a constraint using program
SamuelAlexander
I it possible to disable and enable a constraint using program.
What constraint ?
Martin Hanák
like for example there are three constraints used for assembling a component, I want to ask is it possible to add a fourth constraint and activate it whenever I need by disabling the third constraint through pro programming.
you can defined two constraint sets. In relations you can set PTC_CONSTRAINT_SET according your needs.
MH
Martin Hanák
