dragging extension lines
cromero
3-Newcomer
In R2001, to drag both ends of a dimensions extension lines at the same
time, you could select one side (on the line, not the end), then select the
end of the other, then drag. What is the trick in WF 1?
It's a pain dragging each one separately as it's almost impossible to get
them lined up.
Chris
0 REPLIES 0
