file open dialog box
ptc-2747402
dose anyone know how change the defaults in the file open dialog boxfrom list to detail?
KrisR
(To:ptc-2747402)
I have inquired about this on PlanetPTC and as far as anyone knows, there is no way to set the default.
I do it with a mapkey.
BTW -They removed the details page in Creo if you are using a linked
session and aren't going to put it back in per a ticket I opened up with
them.
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
In Creo 2.0 config option:
file_open_default_view DETAILS
/Bjarne
