how to apply bearing constraint?
rohit_rajan
how to apply bearing constarints at the end of the shaft as shown in the image below?
6 REPLIES 6
Is this for a Mechanica study or a MDX/MDO analysis? Depending on what your goal is, the answers will be very different. Is it a ball bearing, a needle roller bearing or a bushing that is supporting the shaft?
thanx for ur reply...
it is for sperical roller bearing. i also do not know how to calculate the reaction force on the the bearings?
OK, this helps, but you still did not mention if this is for Mechanica or MDX/MDO use.
oops sorry...at present we want it on mechanica.
OK, good - I have an excellent reference at PTC's website that will address your problem pretty closely:
http://www.ptc.com/cs/cs_25/howto/mst6864/mst6864.htm
It does assume that the support is an ideal "point" support, but it's a pretty good approach to simulate a shperical bearing support. I think it will do a nice job for what you'd like to accomplish, short of modeling the shperical rolling elements and races in detail.
Cheers,
Chris
thanx a lot for your reply..but i am not under maintenace....i am not allowed to see that link.
