how to create button with drop down in quick access toolbar in creo 2.0?
ssharma-6
2-Explorer
I am trying to create a button with drop down menu in quick access toolbar like a button whose name is open and in it's drop down menu option will be .prt, .asm, .drw.
For example please see the attachment.
8 REPLIES 8
I think that requested functionality is not available in CR2.
MH
Martin Hanák
pushkarkhanna
(To:ssharma-6)
Hi
You can use these mapkeys & add mapkeys to drop down menu & change the button image as desired
mapkey om @MAPKEY_NAMEOpen Manufacturing File;\
mapkey(continued) @MAPKEY_LABELOpen Manufacturing;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdModelOpen`
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Open `file_open` `Type`;~ Close `file_open` `Type`;\
mapkey(continued) ~ Select `file_open` `Type` 1 `db_37`;
mapkey op @MAPKEY_NAMEOpen Part File;@MAPKEY_LABELOpen Part;\
mapkey(continued) ~ Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdModelOpen`
mapkey(continued) ~ Select `file_open` `Type` 1 `db_2`;
mapkey oa @MAPKEY_NAMEOpen Assembly File;@MAPKEY_LABELOpen Assembly;\
mapkey(continued) ~ Select `file_open` `Type` 1 `db_1`;
mapkey od @MAPKEY_NAMEOpen Drawing File;@MAPKEY_LABELOpen Drawing;\
mapkey(continued) ~ Select `file_open` `Type` 1 `db_4`;
Hope this helps
Pushkar
Hello Pushkar,
Thanks for the answer!
Actually I have already made map key.
My question is how to create drop down button in the quick access ribbon in Creo 2. for more clarification please see the picture.
Kevin
(To:ssharma-6)
Create your group Cascade on the ribbon then go to the Quick Access Toolbar definition and you should see your group or cascade which you can add to it.
ssharma-6
2-Explorer
(To:Kevin)
Hello Kevin,
Thanks for answer!
can you explain. i don't understand
Thanks in advance
Kevin
(To:ssharma-6)
The Quick Access Toolbar doesn't have the commands to create the groups or drop down menus. To create those you need to do it in the Customize Ribbon Dialog.
Add a new tab or group, if you add a tab it automatically adds a group. The drop down list you show is what is referred to as a Cascade. Add a Cascade under the group, rename it, and add your mapkeys to it.
Go to the Customize Quick Access Toolbar and you should find the menu you created which can be added to the toolbar.
You can then go back and remove the group from the Ribbon if you don't want it shown there.
ssharma-6
2-Explorer
(To:Kevin)
Hello Kevin,
Many Thanks, Problem is solve now.
Thanks Again!
Dale_Rosema
(To:ssharma-6)
Sachin Sharma
Don't forget to mark the appropriate answer as correct for those who may search on this in the future.
