opening models with older versions
ptc-3226336
I am a new user pro_E wildfire3.0. Is it possible to open models created using wildfire3.0 with wildire 2.0? If sol how kindly guide me
Srikanth You need have readnewermodel.dll file sent to you from [-]. Send a mail requesting for it and rest where to load it, will be sent to you. Your wildfire3 model will open in wildfire2 with history tree but it will not be editable, only new features can be added. Denzil
or in wildfire 3 save the part as a neutral file. then open the neutral file in wildfire 2. Again will not have model history.
