palette scale parameter
ptc-1077260
We put several company logos into plastic parts. I am trying to create UDFs to help speed the process up. Right now, we are using saved sketches that are imported in from Adobe. These work fine, but once you bring in the logo you have to dictate the SCALE and ROTATION of the artwork. Once you have placed the sketch you are locked with that scale. Is there anyway to make that SCALE be able to be modified?
Thank you,
James
I got around this problem by making a logo part file of surfaces extruded from the sketch from which I used Publish/Copy geometry. I create a coordinate system on a datum point so that I can move the logo around on the plastic part. I've had good luck resizing the logo by scaling the logo part itself, which then propagates back to the plastic part.
