Zebra Stripes, Rendering
Hi everyone,
People who have used them will know what I'm talking about... how do you
get them on a model?
I've seen them used at last year's PTCUser conference but I can't
remember how to get the zebra stripes on a model. I'm pretty sure it has
something to do with rendering, but I'm not 100% certain.
Jean-Frederic Roy, M.Eng
Sr. Mechanical Designer
SPIELO
Phone: 506.862.1460
Fax: 506.852.7640
CONFIDENTIALITY NOTICE: The contents of this email are confidential
and for the exclusive use of the intended recipient. If you receive this
email in error, please delete it from your system immediately and
notify us either by email, telephone or fax. You should not copy,
forward, or otherwise disclose the content of the email.
    Jean-Frederic,
    You don't have to go into rendering to do this. Pick Analysis,
    Geometry, Reflection - pick your surfaces (Ctrl key for multiples) and
    you will see the stripes.
    Mike Brattoli
    Moen Incorporated
    Engineering Systems Administrator
    25300 Al Moen Drive
    North Olmsted, OH 44070
    fred_roy1-VisitorAuthor
    Exactly what I was looking for. Thanks!
    One step further, select the part from the model tree (top item) and it
    will select all the surfaces. All the edges will turn red - hit view
    repaint and it will get rid of the red lines but keep the zebra
    surfaces.
    The same method works for Analysis, geometry, Draft. You can select
    individual surfaces by control clicking, otherwise pick the part from
    the model tree (again top pick). View repaint again will get of rid of
    your selection (red lines) but leave the draft angle colors. Draft
    check - I think it changed between one of the WF versions.
    - This is WF3, I assume it's the same in WF4.
    Jim
    bbrejcha
    Alternate approach for the hi-end users...
    The zebra stripes tool in Pro/ENGINEER is often not using a high enough
    resolution for fine manipulations concerning light reflections used in
    ergonomic or specialized industrial design. So in substitute I suggest
    using hi resolution imagery. (above 2500dpi) I like motogp pictures
    personally. I'll add the images to a room and turn on real-time render. I
    find the crisp edges I get from a high resolution image offers better
    results over zebra stripes.
    Bart Brejcha
    *DESIGN-ENGINE|**EDUCATION*
    Bart Brejecha designengine.com
