problem solve sketch window
gsomaschini
2-Explorer
good morning, when I go into conflict the sketch that I have to update the references, the window is fixed and is not allowed to edit or enlarge .. why? I create in 3 you could be done.
please attach a picture simply catch the screen contents (you can use Snipping Tool) and put it into reply using CTRL+V.
MH
Martin Hanák
