proe create point
ptc-2095208
proe create point
2D:NACA 63-219 175 Data Points 0.997504 0.000340 0.977573 0.002951 0.957655 0.005963 0.937741 0.009333 0.917823 0.013002 0.897901 0.016919 0.877972 0.021026 0.858035 0.025285 0.838089 0.029665 0.818133 0.034134 0.798167 0.038664 0.778191 0.043223 0.758204 0.047772 0.738207 0.052296 0.718199 0.056768 0.698181 0.061157 0.678152 0.065447 0.658114 0.069614 0.638065 0.073645 0.618007 0.077508 0.597940 0.081195 0.577864 0.084682 0.557779 0.087959 0.537687 0.091019
1 REPLY 1
ä½å¥½summer xia, at first you must create a file which called for example test.pts Now you must add in every line the number zero! Because the first value is for x the second value is y and the last value is for z. 0.997504 0.000340 0 0.977573 0.002951 0 If you have done this, create a new part. Then Insert->Model datum->point->offset csys datum point. Choose now the coordinate and click to the button "Import". Select the file test.pts Good Luck! Jürgen 约æ¹
