[ptcuser] - Can't get co-worker latest models
ArnoldCollett
Sounds like you are using a search.pro that is looking in the folder
with the old files. Try moving the old files to a backup folder.
Hope this helps,
Arnold
I think the order of part retrieval is:
1. In session
2. folder the assy came from (if opened from a different folder
than the working directory)
3. working directory
4. search paths, in order
That's different from the old days where 2 and 3 were reversed. That
change happened in WF1 or WF2, I believe.
I honestly have no idea why PTC changed it, it messes me up all the
time. There's a config option that forces the old behavior, I think,
but I'm not sure what it is. I'm trying to get used to the new default
as it does make a bit more sense to pull the parts from the remote
folder if the assy is in the remote folder.
Doug Schaefer
LinkedIn
Unless you use the config option.
use_2001_search_order yes
Solution Details - TAN
Solution
130928
Type
TAN
Created Date
20-Oct-2005
Last Updated
30-Jan-2006
Title
When Retrieving Assemblies or Drawings in Pro/ENGINEER Wildfire,
Pro/ENGINEER Searches for Components in the Directory From Which the
File was Retrieved Prior to the Working Directory.
Details
Description
When retrieving assemblies or drawings in Pro/ENGINEER Wildfire,
Pro/ENGINEER searches for components in the directory from which the
file was retrieved prior to the working directory.
This behavior is different than specified in the Pro/ENGINEER help
document "Retrieving Files from Other Directories", which indicates the
search order is:
1. In session (in memory)
2. Current working directory
3. Directory containing the assembly or drawing file
4. Directories in the search path
Resolution
In Pro/ENGINEER Wildfire the search order is:
2. Directory containing the assembly or drawing file
3. Active Windchill or Pro/INTRALINK Workspace and Commonspace
4. Current working directory
5. Directories in the search path
The change was made in Pro/ENGINEER Wildfire, datecode 2002020 onwards,
through an internal development project which dealt with retrieving
objects into Pro/ENGINEER from Windchill and Pro/INTRALINK. It was done
to try to avoid opening some objects from local disk and others from the
PDM system. This change was intentional in accordance with Pro/ENGINEER
Wildfire behavior with Windchill and Pro/INTRALINK.
The Help Center document will be updated in a future version of
Pro/ENGINEER.
Alternate Technique
The original behavior can be restored by setting the hidden config.pro
option "use_2001_search_order" to "yes".
