radius creation
Inoram
radius creation
CREO2 M120. remodeling a geographical nightmare that someone created. Pic 1 is what I need to do, pic 2 and 3 is removing it with Flex, Pic 4 is putting it back on with normal radius tool.
And ideas? I thought there was a way in the past to stop radius from being created on tangent chains? maybe that would do it?
There is also a .5 radius on the lower side, Pic 5, this might be key, too. What I dont have is a good picture of what they look like blended together, although it is amazingly close to Pic 1. (it doesnt wrap around like you would think; it just ends).
Pic 5 the radius isn't supposed to continue to the right. (pic 5 is putting the .5 radius on first.)
15 REPLIES 15
TomD.inPDX
(To:Inoram)
One of my early Pro/E failures in a paying contract was managing radii. Although many new buttons were added, it is still a very poor tool with an extremely high CPU overhead. I promise you, SW dances all over PTC's grave with this one on the face of things.
However, your problem should be resolvable in today's Creo. The thought is to try the guide curve. The second is order of operations. The 3rd is exclusions. And finally, but not recommended (hail Mary) is the variable radii.
Is it figure 4 you are trying to achieve? If you provide this section of the model, I can see what I can do with it.
Inoram
(To:TomD.inPDX)
This is the goal.
TomD.inPDX
(To:Inoram)
Emailed you back a reply. It seems that following a curve on the top surface is the best way to terminate the round. I did make the 0.5R first. This is the "through curve" option for rounds. The curve sets the radius so it can be continually variable. I believe the curve is required to be tangent from start to finish.
Thanks for sharing your solution, Matt. Using the transition option makes this much simpler.
The answer is so intuitive; how could I have missed that
Inoram
(To:TomD.inPDX)
thanks for the help!
Funny how two people can have opposite impressions. Rounds in SW drive me batty. Have a surf to surf round that you want to be an edge round now? Delete and start over. A constant round that needs to be variable? Delete and start over.
And the thing is, deleting a feature delete the children, period. No option to leave them hanging, just delete. It's odd to me because if they fail, SW can skip by them and leave them failed, but if you deliberately delete all the children have to go too.
So you either recreate the children too or somehow redefine them ahead of time so they no longer reference the round you want/have to delete.
Creo's UI in rounds (and many places) is less than ideal, but the underlying functionality is quite robust in my view. It's just getting to where you control it that can be difficult.
LinkedIn
dgschaefer
(To:Inoram)
It defaults to a tangent chain, but you can select individual segments as well. That's done in the "Details" dialog. Look for the "Details" button nest to the edge selection box. In there, select "Rule-Based" and then re-select "standard". Creo should convert the single reference into a set of all the tangent references. You can then remove the last edge from the group and I think you should get what you want.
Those picks are based on looking at WF4, but I think that dialog is still the same in Creo 2.
LinkedIn
you can also press shift and select the single edge for radius to avoid pro/e assuming that you want tangency round.
"pieces" option can also help you to drag it back to a single edge.
It wasn't a matter of which edges were selected. It was a matter of how it did the blend at the end. There are two transition solutions but you have to have both sets in the same round feature.
I am not sure how Matt finally got to his solution but I ended up with the same geometry using the transition button.
Inoram
(To:TomD.inPDX)
Basically what Doug said. In the Details options.
I am not sure what software this model was originally done in, but some people designing plastic parts need TO BACK OFF THE RADIUS TOOL. lol... radii on top of radii on top of radii....
In fact when I discovered CREO had an auto round tool, I was like NNOOOOOO..
TomD.inPDX
(To:Inoram)
Okay, now I see.
This is the one I came up with. It is the same result:
Video Link : 5219
dgschaefer
(To:Inoram)
I actually used the auto round on a part recently, and it worked fairly well.
Then I realized:
  1. I now have zero control of what edges get roudned and what don't. If the model changes, the round scheme may be completely different. Not cool.
  2. It takes forever to regen. For-ev-er.
It was a good experiement, but I'm going back to adding my own rounds.
LinkedIn
It was #2 that had me comment on the SW perfomrance. I can add 100 radii to a cast part with ribs and it wouldn't even flinch on performance.
i agree solidworks is fast on this.
