restricted parameter
mcaoyl2
Dear ProGurus,
I am creating proProgram and in the input area, i have parameter "A".
However, later i would like to limit this A value to certain range which i
create using restricted range method.
However, when i open the parameter box, i cannot tick the exisitng A to
become restricted parameter.
I have to go proprogram, delete parameter A, then delete A in parameter box,
then recreate new parameter call A and check the restricted box.
then only i am able to limit the A wihin the range value.
I also notice that there are precedence depends on where we create the
parameter.
Any advice?
THanks in advance.
0 REPLIES 0
