sketcher button defaults
ptc-2756516
i would like to change the order and the default option for the sketcher buttons (eg which one is first and which one 'pops-out'. can you help?
Kevin
(To:ptc-2756516)
In a part start a sketch feature and once you are in the sketch environment select Tools>Customize Screen. Under the Commands tab select Sketch to add sketcher tools. You can select items on the tool bar and drag them to the locations you want. You can also add new menus and flyouts from the New Menu selection at the bottom of the list. Make sure you have the check box Automatically save to selected and the file set.
thanks!
