Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Hi, Does anyone ever tried to use a solid created in UG within ProE? Is there a special setup to use? In my case, few solids are well transfert, but not all of them, curves everywhere and so one... Thx in advance, David
The set up we have had most success with is as follows Export the UG model with Step 203 translator in Unigraphics Open a blank modeling file in ProE Using "shared data from file" bring in the saved step file Nine times out of ten it comes in as a solid although round features have a fault warning as they are not made from two semi-circles.
