solid from UG to ProE
chibouki
Does anyone ever tried to use a solid created in UG within ProE? Is there
a special setup to use? In my case, few solids are well transfert, but not
all of them, curves everywhere and so one...
Thx in advance,
David
The set up we have had most success with is as follows
Export the UG model with Step 203 translator in Unigraphics
Open a blank modeling file in ProE
Using "shared data from file" bring in the saved step file
Nine times out of ten it comes in as a solid although round features have a fault warning as they are not made from two semi-circles.
