solid modelling help
majd
I am a new user to pro-e. Can some one help me out in creating my model please. I have solid models A and B.I want to carve model A so that model B fits accurately in it.
Let me re-define the problem, Can solid model B be deduced from solid model A so that a cavity is created in model A?
Actually model B has a 3D profile which can't be sketched in 2D plane.
Majd
Send instant messages to your online friends http://uk.messenger.yahoo.com
1 REPLY 1
martymac
(To:majd)
You need to use the "CUTOUT" feature while in assembly mode. So you start
with parts that interfere, then pick the part to be cut, and then the part
that will make the cut.
_____
