summary: dec. places in a table
JackDillon
After the text for the parameter, you call out the number of decimal places using square brackets. Example:
&length[.4]
3 REPLIES 3
That would be true if you manually put in each parameter in to the table
but not when you use repeat regions.
Brian S. Lynn
CAD Administrator/Designer
It does work with simple repeat regions. I am not sure about 2D
Example.
&fam.inst.param.value[.0]
[&rpt.rel.convert[.1]]
Luis
I tried it this morning and couldn't get it to work, so I assumed it was
lost in the fire.
Brian S. Lynn
