Is there a good way to have multiple different custom color schemes available withou having to browse to a new syscol.scl file for each one?
thanks
Greg
I use 2 different colour schemes and i use mapped keys to switch between them. I have named my mapped keys cs1 & cs2.
Selections for the mapped keys are as follows:
File -> Options -> System Colors
Go to Color Scheme drop down box and choose Custom
Click on browse and select the location of your SCL-file.
Save the mapped key selection process and you should be good to go.
FYI im using Creo 2 M120.
Best Regards
Best Regards
