tiresome process of making slots
SamuelAlexander
Is there any easier way to make slots rather than joining two circles with two tangent lines
samuel
While you are in the sketcher mode: Sketch>Data from File> Palette> shapes>racetrack. Drag and drop the racetrack into the graphic area. Then modify dimensions according to your needs.
Celalettin
Celalettin
bp
(To:cgungor)
I added many sketches to the sketcher palette I'd like to use more often.
Of course there isnt a "add sketch to palette" button in Creo because that would be easy.
You can backup the sketch of your slot to the sketcher pallete (just search for "sketcher_palette" directory on your harddrive), you can also place your own sketches in a subfolder in "sketcher_palette" which will then appear as a new tab in the little Palette window.
You can also manually set the directory in config.pro using the setting "2d_palette_path".
