Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
> I would like a little help in getting started creating a wave spring. If anyone can get me start in the right direction it would be appreciated. Mike
I downloaded a wave spring model from www.proecentral.com and learned from that. It was created using a variable section sweep, normal to origin trajectory.
