Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
We are currently on Creo/Elements (Wildfire 5). It looks like we are going to begin discussions next week about upgrading to either Creo 2 or 3. Other than the obvious learning curve to either, are there any concerns or considerations that we should be aware of to help in our decision on which one to upgrade to? Are there any horror stories people have when they upgraded to either of these and are there any happy stories from upgrading to either of these?
I recently managed going from WC 9.1 and WF4 to WC 10.2 and Creo 2.0 at a division of Boeing.
All very smooth. Some ongoing work with config.pro settings, mapkeys, etc. Probably worth re-thinking all of these. There were some issues with multiple skeletons in the early releases of Creo 2 (< M040).
If you publish (assuming use of Windchill), it's common and seems to be a good idea to start using the new release (e.g. Creo 2 or 3) for the CAD worker far ahead of having users on it. Gives some opportunity to see any publishing issues.
We are also on M120 and it's been stable in our environment as well
Mike Brattoli Moen Incorporated Global Product Development Process Management Administrator - PLM President, Northern Ohio PTC User Group Creo 2.0, Build M120 25300 Al Moen Drive North Olmsted, OH 44070
I might hold off on Creo3, I'm seeing some new issues with family tables, regeneration of assembly subcomponents is not working properly. I'm thinking I made the move to Creo3 too early.
Creo 2.0 m100 here with Windchill-based Intralink 10.0 m030. Working fine. (I hope I haven't just jinxed myself...)
Will upgrade the Intralink soon (v10.2 m020 is the likely candidate at this point) but will keep Creo at 2.0 m100 for a while yet.
May move to Creo 3.0 after reported difficulties subside (perhaps m80 or so?)
Scott Pearson Senior Designer CAD System Administrator
[cid:image006.png@01D047A4.FD081B80]S O U T H W E S T R E S E A R C H I N S T I T U T E(r) Space Science and Engineering Division Space Systems Directorate Department of Space Engineering 6220 Culebra Road, San Antonio, TX 78238
oledata.mso
