Jul 27, 2021 4:37 PM UTC
Creo Additive Manufacturing Tips & Techniques Session Recording (East Coast)
  • Apr 10, 2026 1:51 PM UTC
  • 4 replies
  • 2221 views
  • Translate All
Check out this video on Additive Manufacturing from PTC Application Engineers!
Presenters:  Emily Pinto (Virtual Presales Technical Specialist) Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Dayna_M14-AlexandriteAuthor
Aug 4, 2021 6:51 PM UTC
Webcast Q&A
Question from Adam:  How are the lattices represented in large assemblies?  Will they slow down top level models due to a large increase in surfaces?
Answer:  It is not a traditional pattern so once created will not need to regenerate.  You have added a lot of surfaces so that might slow down graphics but there are simplified representations to help with that.
Question from Adam:   Does the analysis only run stresses?  Or will it do thermal, electrostatic, etc.?
Answer:  Structure, Modal, Thermal, CFD - no electrostatic at this time.
Question from Adam:  Does the analysis take into consideration Ansiotropic properties of a build, and if so, does it update as you change build orientation?
Answer:  This simulation does not.  We do offer Process stimulation though.
Aug 4, 2021 6:54 PM UTC
Webcast Q&A
Question from C:  Changing the imported custom part will update the Aircraft model with lattice shape imported?
Answer:  Yes, a custom lattice is fully associative.
Aug 4, 2021 6:58 PM UTC
Webcast Q&A
Question from Joe:  When defining a custom lattice, I heard you mention that a new part (defining the unit cell) is selected.  When doing so, does the "part" show up as a sub-component in the model tree?  And will the selected unit cell part create a child relationship (meaning the primary design part will always need to see the unit cell in order to properly regenerate)?
Answer:  The lattice is a feature within the model tree.  The area in which you create the lattice is a function of the features that come before it.
Aug 4, 2021 7:01 PM UTC
Webcast Q&A
Question from Michal:  Can Creo AMX allow optimized shapes in accordance with FEA analysis output by stiffening some areas and weakening others?
Answer:  Yes, the spacing and density is a variable that can be changed as a result of Creo Simulate optimizations.
