Creo Cabling/HMX Tips & Techniques Session Recording (East Coast)
100% helpful (1/1)
Check out this video on Creo Cabling/HMX from PTC Application Engineers!
Presenters:  Adam Manfredonia (Presales Technical Specialist, Principal), Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
To dive deeper into the subject, check out PTC University.
Comments
Webcast Q&A
Question from ClaudiuReplacing a connector with a different one, it will be difficult to resolve failures of the cables and wires?
Answer:  The easiest approach is to change the schematic, change the assembly and re-import the XML file.
Webcast Q&A
Question from Jim Is there 3rd party tool for creating data tables?
Answer:  I don't believe there is.
Question from JimWill Creo parametric allow you to add a REF_DES parameter to your 3D models so when you import Creo Schematics that multiple components with Auto-Match on REF_DES parameter?
Answer:  There is likely a way to do that but the REF_DES is assembly specific.  Instead of creating a million REF designations, it is probably easier to just create one component and then define the REF_DES in each assembly.
Webcast Q&A
Question from MichaelHas the output schematic to cabling always been XML format?
Answer:  Yes, that is the format the Creo Cabling understands.
Webcast Q&A
Question from TonyAre there any improvements with flatten harnesses?  In the past, the extension tends to be very cumbersome to use.
Answer:  Yes, this will be shown later in the demo.  This area has the most improvement.
Question from TonyIf schematics is not available for whatever reason, can we still generate .nwf files as a substitute for Creo Schematics for later versions of Creo?
Answer:  Yes, you can still use .nwf for cabling.  That is not going away.
Question from TonyWhat would be the recommended method of locating the cabling network?  I tend to use datum point to avoid assembly references.
Answer:  Skeletons and TDD techniques are your best friend here.  That way you can control the external references created.
Version history
Last update:
‎Jul 27, 2021 01:40 PM
Updated by:
Labels (2)
Tags (2)
