Check out this video on Creo Render Studio from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow).
Click here for Creo Render Studio Learning
Webcast Q&A
Question from Douglas: Will you review control of the camera (viewer) position? In one case I needed to understand the visible reflections in a mirror but couldn't find exact camera position controls.
Answer: Add an appearance to the combined state, and then once you switch to that combined state, choose the render option to render that appearance in the current state.
Webcast Q&A
Question from Eric: Would it be a good practice to use decals to create product labels? Today, we create labels as an extruded part and assemble to flat surface with relative ease, but have difficulty with curve surfaces. If so, would it show on a drawing?
Answer: Yes, you can render an exploded view.
