Mar 27, 2024 1:20 PM UTC
Creo Sketcher Tips &. Techniques
  • Apr 7, 2026 8:36 PM UTC
  • 6 replies
  • 19429 views
  • Translate All
Check out this video on Creo Sketcher from PTC Application Engineers. Presenters:  Emily Pinto (Solution Consultant), Lino Tozzi (Technical Specialist, Fellow) & Tom Quaglia (Creo Segment Sales).
Mar 27, 2024 5:56 PM UTC
WEBCAST Q&A
Question from Anonymous:  What is the difference between a Palette section and a UDF?
Answer:  Palette is just for a sketcher.  UDF is for the entire feature or multiple features.
Question from Anonymous:  How about palette for a body instead of a sketch (like a sub part)?
Answer:  For other features and bodies, you can use UDFs.
Question from Anonymous:  Can you please put the palette folder name here?
Answer:  The config.pro option is:  2d_pallette_path
Question from Anonymous:   How do I get config.pro file to always run?  My settings always reset.  I tried Google, but no luck.
Answer:  You would need to save the config.pro file after editing and make sure it is seen on startup.
https://support.ptc.com/help/creo/creo_pma/r8.0/usascii/index.html#page/fundamentals/fundamentals/fund_five_sub/About_Configuration_Files.html#
Mar 27, 2024 6:01 PM UTC
WEBCAST Q&A
Question from Brian:  How did that "tips and techniques" tab get added to the palette?
Answer:  By creating the folder and putting the .sec files in them.
Mar 27, 2024 6:03 PM UTC
WEBCAST Q&A
Question from Christian:  When I create a centerline and want to specify a diameter using the "dimension" button, I can only specify the radius.  How to I specify the diameter?
Answer:  You need to select the line twice and you will get the diameter.
Mar 27, 2024 6:05 PM UTC
WEBCAST Q&A
Question from Dhanashri:  Can we create Palette in system files?
Answer:  Yes, as long as there is a visible path.
Mar 27, 2024 7:02 PM UTC
WEBCAST Q&A
Question from Diana:  How did you add the image for the grip?
Answer:  View/Model Display/Images; Import, place and scale the image.
Mar 27, 2024 7:06 PM UTC
WEBCAST Q&A
Question from Nadeem:  Can we save sketches in a local folder, and access them through the palette?
Answer:  yes
1. Create a new section or retrieve an existing section
2. Save the section to the subdirectory corresponding to the Sketcher palette tab within the Sketcher shape directory
The file name of the section appears as the name of the shape along with the thumbnail of the shape within the Sketcher palette tab
