Check out this video on Creo Unite/Import Data Doctor from PTC Application Engineers
Presenters: Lino Tozzi (Technical Specialist, Fellow) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: October 26, 2021
To dive deeper into the subject, check out PTC University.
(Pop-out video for best experience and full screen option)
Webcast Q&A
Question from Brad: I use IceM Surf 2020. It is a .icem file format. Is this available?
Answer: Yes, it is on the file open list as *.icm.
Webcast Q&A
Question from Kevin: Is there a config setting that will copy geometry when external references are created?
Answer: Not an option to automatically copy geometry any time an external reference is made. However, using an advanced assembly technique you can accomplish this. Here is a link to the Advanced Assembly T&T session for your reference. https://community.ptc.com/t5/Creo-Parametric-Tips/Creo-Advanced-Assembly-Tips-amp-Techniques-Session-Recording/m-p/739495#M670
Question from Kevin: Are there any cases to use ATB going forward?
Answer: No, Unite should be used in all cases.
Webcast Q&A
Question from Mark: Can Creo be used to edit automotive class A surfaces? Or is surfacing software like Alias serve a different market segment?
Answer: Yes, it is best to create the natively in a single tool (Creo Parametric/ISDX). It is difficult to import class A surfaces and get good quality.
Webcast Q&A
Question from Raghu: Is all the functionality shown today included in all licenses of Creo, including the most basic one?
Answer: Yes, with SolidWorks and CATIA for United collaboration. Importing any native file format is also in all current packages. Import Data Doctor is in every license we sell currently.
