Check out this video on Creo View from PTC Application Engineers
Presenters: Jason Petersen (Solution Consulting, Principal) and Ryan Butcher (Solution Consulting, Fellow).
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
Webcast Q&A
Question from JP: Are any WTPart attributes passed to or available from Creo View? Or only CAD attributes?
Answer: Windchill attributes can be displayed in Creo View also, when connected.
Webcast Q&A
Question from Kevin: Can Search Groups be shared among users?
Answer: This can be done through sharing Creo View preferences.
Webcast Q&A
Question from Marco: Can I export as a shrink wrap just to save a Single model an assembly?
Answer: No, that is only a Creo Parametric function.
Webcast Q&A
Question from Marvin: Is an additional license required to open JT in Creo View MCAD?
Answer: Yes, an additional license is required.
Webcast Q&A
Question from Robert: Are changes to the Creo View file saved back in to Windchill? Is a check-out/check-in needed?
Answer: Annotations can be saved to Windchill. All changes to the geometry are made in the CAD system and update the Creo View file that is stored in Windchill.
Please change this subject above from Creo Schematics to Creo View.
Check out this video on Creo Schematics from PTC Application Engineers
