Check out this video on Augmented Reality from PTC Application Engineers
Presenters: Ryan Butcher (Technical Specialist Fellow) and Lino Tozzi (Technical Specialist Fellow)
Original Date Presented: February 23, 2021
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Scott: Is there a way to publish these AR models in a remote environment? Separate from PTC website or servers?
Answer: The "Freemium version is only through the PTC Cloud. There is a solution to bring it to internal to your environment through the full version of Vuforia Studio.
Question from Scott: If an added distance is greater than the distance to Target Plane, can you make it float in free space?
Answer: Yes, it will appear to float. The target will snap to the floor or table you're setting it on.
Webcast Q&A
Question from Roman: Do we really need Windchill or can we publish directly from Creo Parametric or Creo View?
Answer: You don't need Windchill. You can go directly to Parametric or View.
Webcast Q&A
Question from Bruce: Can an AR publication be recorded and saved to be circulated and viewed later (i.e. manufacturing, training, service, engineering...processes/procedures)?
Answer: Those solutions are with our extended suite of AR tools, Vuforia Studio, Expert Capture & Chalk. https://www.ptc.com/en/products/vuforia
Question from Bruce: Can multiple AR publications be viewed at once?
Answer: One experience at a time.
Webcast Q&A
Question from Martinez: Can the person viewing the model in AR access view states for the model like a section view or exploded view?
Answer: Yes, that is available in Creo Parametric 7.0.3
