Check out this video on High Speed Machining from PTC Application Engineers
Presenters: Lee Goodwin (Technical Specialist, Principal) and Lino Tozzi (Technical Specialist, Fellow)
Original Date Presented: September 28, 2021
To dive deeper into the subject, check out PTC University.
Webcast Q&A
Question from Jon: How does cutting a tool debur when cutting leaves a bur? Is this some kind of special debur tool?
Answer: Does not require a special tool. Just go use a ball end mill.
Webcast Q&A
Question from Mark: Does Creo NC work with all major CNC manufacturers? Haas, DMG Mori, etc. Is there a predefined list of machine you can select from?
Answer: Yes, Creo NC includes g-post and we can support any manufacturers.
Question from Mark: How about SolidWorks or NX models? Do they have to convert it to STEP?
Answer: No need to convert. Can be native SW or NX or most other CAD models.
