To help showcase the accuracy of Creo Simulation Live, PTC has conducted a series of tests comparing the result found in Creo Simulation Live to Creo Simulate.
Our findings show that as long as the physics of the problem can be modeled with linear static, modal and steady state thermal assumptions, then the results in Creo Simulation Live will not differ by any significant amount from traditional FEA codes such as Creo Simulate, and many others.
The value of having near real-time results feedback, completely inside the design environment is enormous, and will revolutionize the way simulation is used to drive designs!
