You may try adding config gpi_to_parasolid as yes in config and export data as parasolid.
@ maheshSh I had a similar issue and this seems to have fixed it.
What does this config option do?
What model accuracy are you using and what is the value?
If I recall correctly NX uses an absolute accuracy of 0.001 mm by default. Perhaps this is causing the problem?
