This model was created with PTC Creo 2.0 and rendered with KeyShot.
I used style surfaces (ISDX) and splines. Blueprints as references.
All files included:
- Creo 2.0
- Keyshot 5.0
- IGES
- STEP
- Parasolid
Download this model and all files:
Very nice!
Thanks !!!
Fantastic work.
Just one question.
Is it possible to obtain the same quality of imagem you´ve got only using the creo rendering tool?
To some extent it's possible if you have the advanced rendering extension (which uses iRay or mentalRay if I remember correctly) but it won't be as intuitive as with Keyshot. Also the camera controls in Creo are really poor and not very easy to use if you want to obtain good results
Thanks!
Thank you by the remarks.
