I can't seem to find how to change the sheet size for this function when creating drawings. I need to alter between 8 1/2 x 11 and 11 x 17 depending on the particular job. Is it a setting in Creo ? Creo Parametric 2.0 M040
-- Carl Lever Yorkville Sound TEL: 905.837.8550 ext. 222 FAX: 905.837.8746 clever@yorkville.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
