~hey all,
ok--Looked thru help(less)... found nothing buried...
Is there a way to show dual dimensions in a 3D dimension-driven annotation element in a part/assembly model? The dual dimension radio buttons are grayed out in the annotation properties dialog. Seems there should be a method if we're driving toward model driven dimension vs. drawings. Or haven't they gotten that far yet?
WF4.0 M130
tia
_mark
I'm not sure about WF4, but in Creo 2.0 you are able to place dual dimensions. Its an on/off setting in the model dtl file.
