im trying to add a tolerance to my counterbore on a hole. but i cant get it to show up..
here is my dimension callout..
@D x 21.70
v &d79 x &d78
i need the &d79 to show the tolerance. i checked the model, and its showing in the model.
thanks
Check the drawing options, tol_display needs to be set to yes. You may also need to set the display from the dimension properties.
