Dimension Tolerence
Brijith
Dimension Tolerence
Hello All,
Can anyone help me to remove the trailing zero for the dimension tolerance (drawing config option)? Please refer to the below/attached image.
Reg,
Brijith
3 REPLIES 3
kdirth
20-Turquoise
(To:Brijith)
This is a detail option in the drawing.
File / Prepare / Drawing Properties / Detail Options
dim_tol_lead_trail_zeros
Hi Brijith,
Did the detail option work for you?
Amit
BenLoosli
23-Emerald II
(To:Brijith)
In ASME Y14.5, you cannot remove it even if you turn off trailing zeros in your .dtl file. The + and - tolerances must have the same number of decimal places, unless one of the values is 0.
