How can I export file from creo 2.0 to Ansys WB 13.0
Please help if anyone know this.
You can export your file as a neutral format (IGES, STEP...), then Ansys should be able to read it.
How can I save the CREO's .prt or .asm file to Neutral format?
You might check out the CAD plugin module for workbench. Lets you work with native pro/e files directly but requires a pro/session.
in workbench geomety you can right mouse on geometry import cad
I think this article will be helpful for you:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS36584
