Export *.prt , *.asm to parasolid
JoakimAndersson
Hi.
How to export a model to parasolid with curves? (I don't mean Wireframs edges)
Can't find parameters like export to step.
Parasolid is a 3D solid model file format, it does not support curves. If you need to export curves and solid bodies from Creo, you need to use IGES or STEP.
Ben's response is correct.
