Feet & Inches
bbenitez
Feet & Inches
Hello all -
I have a student who is doing some room layouts for management in CREO2
How does one get the dimensions to display in feet/inches.
I used to know how to do it in WF - but alas . . . .
Anthony R. Benitez
Senior Mechanical Designer - Supervisor
Applied Research Laboratories - The University of Texas at Austin
This email and/or attachments contains export controlled material under
applicable laws of the United States. This material should only be handled
by US persons (a person that is a permanent legal resident of the The United
States or a protected individual) and should not be shared with any non-US
person.
You need config options and detail setup changes.
I have these two mapkeys in Creo that turn this on and off, the required files are attached. Obviously the paths will need to change to match your environment.
!== Load Configs to change drawing to feet, inches, fractions ==
mapkey .fif @MAPKEY_NAMESet Feet Inches Fractions;\
@MAPKEY_LABELSet Feet inches fractions;\
~ Command `ProCmdRibbonOptionsDlg` ;\
~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
~ Activate `ribbon_options_dialog` `ConfigLayout.Open`;\
~ Update `file_open` `Inputname` `P:\\mapkey_configs\\fractions-config.pro`;\
~ Command `ProFileSelPushOpen@context_dlg_open_cmd` ;\
~ Activate `ribbon_options_dialog` `OkPshBtn`;\
~ FocusIn `UITools Msg Dialog Future` `no`;\
~ Activate `UITools Msg Dialog Future` `no`;\
~ Close `main_dlg_cur` `appl_casc`;\
~ Command `ProCmdDwgProperties` ;\
~ Activate `mdlprops_dlg` `OPTIONS_lay_Controls.push_Change.lay_instance`;\
~ FocusOut `preferences` `InputOpt`;\
~ Activate `preferences` `Open`;\
~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
~ Activate `file_open` `PRO_DTL_SETUP_DIR_shortcut`;\
~ Select `file_open` `Ph_list.Filelist` 1 `foot_inch.dtl`;\
~ Activate `preferences` `ok`;\
~ Activate `mdlprops_dlg` `DlgClose_push`;
mapkey .nfif @MAPKEY_NAMEUnset Feet Inches Fractions;\
@MAPKEY_LABELUnset Feet inches fractions;\
~ Update `file_open` `Inputname`\
`P:\\mapkey_configs\\fractions-config-off.pro`;\
~ Select `file_open` `Ph_list.Filelist` 1 `de_inch.dtl`;\
David Haigh
Hello all -
I have a simple building layout drawing I'm doing for one of our directors.
I cannot get the dimensions to show as feet & inches.
I've changed major units to "yes" - and changed properties on the dimension
to fractional
What else am I missing?
Anthony R. Benitez
person.
Config options
dim_fraction_denominator 64
create_fraction_dim yes
detail file
! These options set drawing dimensions to foot inch display
default_tolerance_mode NOMINAL
dim_fraction_format AISC
use_major_units YES
I have A config and .dtl file with just these settings, and a mapkey to load them.
David Haigh
Thanks all (David) - this did the trick - I missed the .dtl file.
Anthony R. Benitez
person.
