Hello everyone!
I have a drawing missed the reference of ordinate baseline dimension, how to fix the missing reference?
If delete the dimension, all the related dimension will be also deleted.
The "Edit Attach" function for the baseline dimension is not available.
How to solve this problem?
Thanks for any help!
Rick
I have never been able to fix it if it was the baseline. I try to use the most stable starting feature possible for that baseline dimension.
I hope someone else has a real solution for you.
