I have a title block program that asks questions for various fields when you create a drawing. How do I get it to automatically fill in the title block with the sheet one info when I add another sheet? I am using Creo 3 M100.
don't fill informations directly to tables. Thats bad style and bring up a lot of Problems in later usage.
Better:
- Fill up the informations in parameters.
- Use the parameters inside your drawing frames (tables) with ¶mname; and you should get all informations on all sheets
- Also decide which parameters make sense on your model and which ones are better at the drawing.
So many people work on a "good" parameter concept in different companys. One advantage is that you can replace your drawing frame later and all cells get filled automatically.
You should think about a conversion from your old files to the new standard (if you change to parameters). To get a "all the same" working behavior and a good speedup for you and your colleges.
Tools like:
B&W Smart Update https://www.buw-soft.de/index.php?id=smartupdate&L=3
INNEO Model Processor / User (has also a free guest mode) https://modelprocessor.inneo.com/
could help you at this steps.
Br,
Eike
