I cannot remember/find the option that allows the dimension height/font to be increased on the screen in part and assembly mode. I did this in 3, 4 and 5 during the period my eyesight decided to head south.
Can you guys remember what that oneis?
Try TEXT_HEIGHT_FACTOR
Bigger numbers = smaller text
Also, Pro/E may need a reboot to take effect.
x
Thanks....All
FYI...TEXT_HEIGHT_FACTOR is not shown as a config option
Correction.....I am wrong....David Schenken is correct. TEXT_HEIGHT_FACTOR is the correct config option.
It is a hidden config option which is why I could not simply click "find" and well, find it. Thanks to David for saving an old(er) man's eye for a little while longer.
