Pro/E Exploded views
ptc-3176014
I am making an assembly drawing, to show how something would be assemblied in the shop. One of the components sets on the table, 90 degrees from other part that assembles to. Is there a way to show this in an exploded view? Common practice around here amongst other users is to make 2 views on the drawing. The views are 90 degrees apart, then trimmed to partial views, showing only the area they want.
if that component also goes into this same assembly i would just add it to the asembly model and explode it too... unless i misunderstood something from ur description...
cdiaz-2
11-Garnet
(To:cdiaz-2)
sorry, now i see what u mean, i would create a simplified rep like the view on ur pdf, and explode the rep, so then ur master rep would be the way its will be when assembled. thats just me and its the first thing that comes to mind, probably 20 different ways to achieve the results u want. Carlos
