Splitting the screen.
gfraulini
Hi all,
within the "style" environment (edit ->style), under the "View" menu there is the command: "Show all views"
This command allows to split the screen into 4 parts.
Is there the same possibility outside the Style?
Bye
1 ACCEPTED SOLUTION
No, this feature is unique to the Style modeling environment.
LinkedIn
LinkedIn
I once used Pro|Engineer Jr.
It had this built-in but when they upgraded us to full blown Pro|E, I lost the functionality.
Really sad 😞
llie
(To:gfraulini)
Doug is correct. Style is the only feature that you cannot split your screen like you can in Creo View or even SolidWorks.
