Tolerance Analysis STP files
Visitor
is it possible to do a tolerance analysis with step files? I got a assembly with two bearing models from a supplier. The geometry is a imported feature so i can not change any dimension, eg the length of the bearing.
How can i do a tolerance analysis with imported features or step files?
thanks
Simon
1 REPLY 1
Highlighted
Re: Tolerance Analysis STP files
If you have the flexible modeling extension you can make dimensions that are changeable.
You can change lengths/ radii/ number of features, anything.
try
https://www.youtube.com/watch?v=MdtUzCv_vWw
Erik
http://www.ptc.com/product/creo/flexible-modeling-extension Paul Sagar, Product Management Director at PTC introduces and demonstrates the Creo Flexible Modeling Extension available for Creo Parametric. The Creo Flexible Modeling Extension (FMX) gives Creo Parametric users more freedom to ...
